Announcements
script to Query for number of reversed and Overlapping UVs
RichSuchy
RichSuchy
Is there a queryable command that returns the number of overlapping and reversed UV's an object has. I want to write a check in script that parses a selection of models and prints a report about the selected models. Found two python scripts online but neither have propper syntax and don't do what I am looking to do.. The UV editor hud shows this information in the lower right corner so it seems it would be simple. Looking through the mel commands I came up dry.
malcolm_341
For backfacing select your object in object mode
SelectUVMask;
SelectUVBackFacingComponents;
For overlapping
SelectFacetMask;
selectUVOverlappingComponents 1 0;
RichSuchy
Thank you so much!
RichSuchy
I tried to create a quick test of the Backfacing UV counter.
I might be missing something simple here but is there a reason this would not work. My array appears empty even though I purposely created bad UVs. The bad UVs are displayed after the command but not captured in my array.
SelectUVMask;
string $backFaceing[];
$backFaceing = `SelectUVBackFacingComponents`;
$strSize=size($backFaceing);
print $strSize;
clear $backFaceing;
$strSize returns 0
malcolm_341
It looks like defining the selection can't be done at the same time as creating the variable, you can do it like this to get the result you're after.
SelectUVMask;
string $backFaceing[] = `ls -sl -fl`;
$strSize = size($backFaceing);
print $strSize;
clear $backFaceing;
RichSuchy
I wish these commands had some documentation. Thanks a bunch, That is indeed a solution (slapping forehead for missing the obvious)
malcolm_341
Yeah it would be nice if the mel reference had been updated in the last 10 years, it seems really out of date.
