How can we List all blendshape nodes of a object?
5rivamsi
5rivamsi
I tried this
shapes = mc.listConnections(objectShape,s=1,type = 'blendShape')
however it gave only one (most recent one) output while the object has 3 shapes.
later i tried
with shapeEditorManger, it listed all blendshapes in scene, I wanted only particular object's.
5rivamsi
def getHistoryNodes(sel, type):
sortedList = []
for aNode in mc.listHistory(sel):
if mc.nodeType(aNode) == type:
sortedList.append(aNode)
return sortedList
selected = mc.ls(sl=1)[0]
print (getHistoryNodes(selected, 'blendShape'))
lost sourcelink
mcw0
You can also use "getChain" and filter non-blendShape nodes.
zewt
You definitely don't want to use listHistory.  That'll include blendShapes on other shape nodes that aren't actually deforming that shape, like blendShapes deforming upstream blendShape targets or morph targets.
mcw0
Unfortunately, getChain isn't as useful as it could be.  It doesn't return the list of deformers in order.  😞  So I have to use listHistory in conjunction with getChain to get what I want.  Uh Maya...hint, hint.
zewt
Try listHistory with -pruneDagObjects 1, which will make it stop if it reaches a different shape.  I'm not sure if there are any other gotchas, but that's what the input/output button in the toolbar uses.  With PyMEL:
import pymel.core as pm
for node in pm.ls(sl=True):
    print(node.listHistory(pruneDagObjects=True, type='blendShape'))
I wouldn't use getChain.  It looks like an ancient bit of MEL that nothing in Maya itself is actually using (usually a bad sign), and it looks like it hasn't been updated for 2022.  It still assumes groupParts nodes exist for deformers, which they usually no longer do, and at a quick look it seems to make bad assumptions about groupParts nodes (it seems to assume there will never be two groupParts nodes in a row, which happened all the time).  That's probably why it's not returning results in the correct order.
mcw0
Thank you very much!!!
