Announcements
In mel is it possible to create a linear curve from selected vertices?
malcolm_341
malcolm_341
Hi, I'd like to create a curve from selected vertices, the problem is Maya doesn't store the selection order for the vert array so the curve gets created with points in the wrong order and the curve gets wonky. Is there a solution for this, or is there a hack to get the vert array to sort in the order you selected it?
stephenkmann
 Turn on "ordered selection" in your prefs and use the -os flag with your ls
malcolm_341
Thanks a lot, that's what I needed.
