Script/ Code Component tag editing in Maya 2022
cmwVXDCP
Message 1 of 10
cmwVXDCP
In Maya 2022, Is it possible without creating a custom node to edit component tags on a mesh or a cluster via
script?  I did manage to find the code to query weights and indices using maya.cmds.geometryAttrInfo.  However,
unlike using the objectSet support from Maya 2020 and prior, I'm not seeing how to edit component tags
procedurally?  For example, I want to add points, remove points to component tags from Python or C++.  I also
want to be able to query component tags on meshes and deformers.  I also want to set a cluster to use component
tags from script or C++.
Replies (9)
Message 2 of 10
absoluteKelvin
im looking for this as well. but i have a feeling they havent implement it yet in script
https://www.artstation.com/kelvintam
Message 3 of 10
cmwVXDCP
It is still possible to edit the cluster weights over the entire mesh using the MFnWeightGeometryFilter.
Message 4 of 10
absoluteKelvin
copied from a post by Will Telford from another thread. Should cover the component editing and querying as well in python.
#Create Mesh
sphere=cmds.polySphere()[0]
sphere = cmds.listRelatives(sphere, shapes=True)[0]
#Create Component Tag
cmds.setAttr(sphere + '.componentTags[0].componentTagName', 'test', type='string')
cmds.setAttr(sphere + '.componentTags[0].componentTagContents', 2,'f[0:99]', 'f[200:299]', type='componentList')
#Query Component Tags
cmds.geometryAttrInfo(sphere + '.outMesh', componentTagNames=True)
# Result: ['test'] #
#Query a description of the componentTags and the nodes in the chain where they were added to the geometry.
cmds.geometryAttrInfo(sphere + '.outMesh', componentTagHistory=True)
# Result: [{'affectCount': 200,
  'category': 4,
  'editable': True,
  'fullCount': 400,
  'key': 'test',
  'modified': False,
  'node': 'pSphereShape4',
  'procedural': False}] #
#Get the components that are members of the "test" tag
cmds.geometryAttrInfo(sphere + '.outMesh', components=True, componentTagExpression='test')
# Result: ['f[0:99]', 'f[200:299]'] #
Message 5 of 10
cmwVXDCP
Thanks.  This is helpful.  Do you know how it would work for vertices and edges also?  Also, what is the argument
which says "2" in the setAttr?  What does the two mean?
Message 6 of 10
cmwVXDCP
Edge example: "e[0:10]"
Vertex example "vtx[0:3]"
Message 7 of 10
cmwVXDCP
For a cluster deformer where it has "cluster1Tag" which is what the default component tag is named once
it is converted, it appears if you run the commands, you are no editing the existing component tag, but creating a new one.  Whereas for custom tags created after the fact with different names such as "test" you can reach in and edit the existing tag.
Message 8 of 10
cmwVXDCP
Also unclear now to reassign a different tag to a cluster deformer once it's tied to cluster1Tag.
Message 9 of 10
absoluteKelvin
2 means two entries f[0:99]', 'f[200:299]'
im unfamiliar with the ClusterTag
Message 10 of 10
mathiasaubry
It's been a while nobody posted on this question, but since I had to find the way to edit the componentTag content, here is the way I found to be more proper than the setAttr, since it seems that you need a eval if you don't know how many entries you have.
here is the way I found to do it:
cmds.componentTag(["geo.vtx[1140:1141],geo.vtx[1150]"], tn='cluster6', m='replace')
and for m (modify) you can use replace, add, remove
and tn being the name of the componentTag
