- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Let’s say I create a 3 joint chain and the distance between the start and end joint has a value of 10 (measured with the distance tool). But if I create another joint chain and the distance has a value of 20, the control should be double the size and so on and so forth.
What I want is to replace the “hard coding” with percentages. So if I create a chain with ‘X’ value (distance tool) the control should scale accordingly.
Images attached
Thanks in advance
Daniel
