Scale with percentages
danispag
danispag
Let’s say I create a 3 joint chain and the distance between the start and end joint has a value of 10 (measured with the distance tool). But if I create another joint chain and the distance has a value of 20, the control should be double the size and so on and so forth.
What I want is to replace the “hard coding” with percentages. So if I create a chain with ‘X’ value (distance tool) the control should scale accordingly.
Images attached
Thanks in advance
Daniel
lanh.hong
Hi Daniel,
You can get the distance from the distance attribute. Then you can set the circle's radius to equal the distance and scale that way. Here's what I came up with based on your sample.
import maya.cmds as cmds
basePos = cmds.xform('joint1', ws=True, t=True, q=True)
endPos = cmds.xform('joint3', ws=True, t=True, q=True)
cmds.distanceDimension(sp = basePos, ep = endPos)
distance = cmds.getAttr('distanceDimension1.distance')
cmds.circle(nr = (0,90,0), c = (0,0,0), r = distance/2)
I hope this helps. 🙂
Lanh Hong
Developer Technical Services
Autodesk Developer Network
danispag
That's exactly what i was looking for. Thank you sooooo much :D.
really appreciate
