Announcements
Python - How to change selection in optionMenu
Craig_Lamorte
Craig_Lamorte
Hi, I am trying to figure out how to change the menuItem selction in an optionMenu but am unable to figure it out.
mymenu = cmds.optionMenu(label ='select type', cc=selecttypecallback)
cmds.menuItem(parent=mymenu, label='selection1')
cmds.menuItem(parent=mymenu, label='selection2')
Now how do I call call mymenu again and check the current selected menuItem to the one i choose?
cheng_xi_li
Autodesk Support
Autodesk Support
Please look at the optionMenu document. It could be used like below.
import maya.cmds as cmds
def printNewMenuItem( item ):
	print item
window = cmds.window()
cmds.columnLayout()
#Please store the menu when creating it
opmenu = cmds.optionMenu( label='Colors', changeCommand=printNewMenuItem )
cmds.menuItem( label='Yellow' )
cmds.menuItem( label='Purple' )
cmds.menuItem( label='Orange' )
cmds.showWindow( window )
#Use optionMenu command
cmds.optionMenu(opmenu, e=True, sl=3)
print cmds.optionMenu(opmenu, q=True, value=True) , cmds.optionMenu(opmenu, q=True, sl=True)
Yours,
Li
Craig_Lamorte
I did look at the documentation and everything i tried couldn't get it working.  I did try what you did in your example and everytime i try to set the selection it says value out of range.  If I print what the selection and value are it will correctly print it, but it wont let me set it.
cheng_xi_li
Autodesk Support
Autodesk Support
Can you tell me your Maya version and give me a sample how you are using this command? My code snippet seems working fine on Maya 2018 Update 1.
Yours,
Li
