Announcements
Find Dag Path from kMesh input
Message 1 of 10
Hi all,
I'm writing a node that has an inMesh input created in the initialize function:
RayIntersectNode.inMesh = tAttr.create("inputMesh", "inMesh", om.MFnData.kMesh)
In my compute function I'm retrieving that data with:
inMeshVal = data.inputValue(RayIntersectNode.inMesh).asMesh()
I'm looking for a way to get the DagPath from that variable. I bellive .asMesh() returns an MObject. Thank you in advance.
- Ben
Replies (9)
Message 2 of 10
cheng_xi_li
Autodesk Support
Autodesk Support
You could find the use MPlug::source to get the source plug connected to your mesh.
import maya.api.OpenMaya as om
selList = om.MGlobal.getActiveSelectionList()
path = selList.getDagPath(0)
path.extendToShape()
print path.fullPathName()+".inMesh is from"
fnMesh = om.MFnMesh(path)
plug = fnMesh.findPlug("inMesh", True)
source = plug.source()
fnDagNode = om.MFnDagNode(source.node())
#We are not initializing MFnDagPath with a proper dagPath, so we'll need to get all possible dagPath because of features like instancing.
#It also could be not a dag object, please check if it is a dag object when you are using MFnDagNode.
pathArray = fnDagNode.getAllPaths()
print pathArray[0].fullPathName()
Yours,
Li
Message 3 of 10
Hi Cheng, thanks for the reply.
I'm confused a bit at the code you gave. Wouldn't om.MGlobal.getActiveSelectionList() require you to give it an MSelectionList() as an argument? I modified part of it but this isn't exactly what I'm going for. I'd like to get the dag path from the inMesh plug without needing the object to be selected.
I looked at the MPlug and MFnMesh docs and I'm not seeing a findPlug method. Am I looking in the right place?
import maya.OpenMaya as om
sel = om.MSelectionList()
om.MGlobal.getActiveSelectionList(sel)
path = om.MDagPath()
sel.getDagPath(i,path)
print "inMesh is from: " + path.fullPathName()
Message 4 of 10
cheng_xi_li
Autodesk Support
Autodesk Support
It is for demonstration only. As long as you could get a plug, it should be working. I am using Python API 2.0, it works more in a Python way instead of C++, so no MSelectionList required for MGlobal::getActiveSelectionList. If you look at inheritance diagram of MFnMesh, you could find  it inherits MFnDependencyNode, it has findPlug method.
Since you are creating a custom node, another way to do that is MPxNode::connectionMade.
I used it in a blog to create callbacks for my custom node. You could check it out if you are interested into that way.
Yours,
Li
Message 5 of 10
Hi Li,
MFnMesh.findPlug would work, but the problem still exists that I can't get the dagPath from my inMeshVal attribute.
I tried another solution after more searching, but it returns "kFailure: Object does not exist". The docs for the MDataBlock.asMesh() or .asMeshTransformed() says "Returns the data represented by this handle in the data block. The object returned by this call may be used directly with the mesh function set (MFnMesh) or any of the mesh iterators." So I'm not sure why it's not accepting it.
dagPath = om.MDagPath()
fnMesh = om.MFnMesh(inMeshVal)
fnMesh.getPath(dagPath)
For context, I'm writing a simple ray intersection node.
Message 6 of 10
cheng_xi_li
Autodesk Support
Autodesk Support
Please make sure it is a DAG node first. This error message usually indicates it is not a DAG node. If it won't be displayed in outliner with Display>Dag objects only enabled, it is not a DAG node and there won't be a dag path for it.
MDataHandle::asMeshTransform is still on the same node and it returns a mesh data with transform matrix applied. If you want source node's plug, you should call MPlug::source to get it.
Yours,
Li
Message 7 of 10
Hi Li,
I'm still unable to get the Dag Path from my inMesh input. The object I'm connecting to it (via the outMesh of the mesh's shape node) is a DAG object and shows up in the outliner when "Dag Objects Only" is enabled.
So the problem persists that I'm not sure how to access the DagPath of the MObject returned by:
inMeshVal = data.inputValue(RayIntersectNode.inMesh).asMeshTransformed()
I tried this:
om.MDagPath.getAPathTo(inMeshVal, dagPath)
dagPath = dagPath.fullPathName()
But it returned: (kInvalidParameter): Object is incompatible with this method //
Maybe I'm mistaken but I thought MDataHandle's asMeshTransformed() function returns an MObject. I'm still very new to the API so it's difficult for me to read the docs sometimes.
Message 8 of 10
For posterity, it looks like you don't need to send an MFnMesh constructor an MDagPath for it to construct. I was able to pass it the inMeshVal I got from taking .asMesh from my input mesh data handle to the constructor and it worked fine.
Message 9 of 10
Hi Ben,
Any chance you could share your code or elaborate on how you solved this? I'm trying the same things you mentioned and am having no success. Even someone in this thread says it's not possible to get a dag path directly from the mesh data returned from .asMesh() on a datahandle.
https://forum.highend3d.com/t/dagpath-from-a-mfndata-kmesh-attribute/40293
I'm trying out one of the other ideas from that thread, which seems to be about tracing the plug back to the input mesh and getting the DAG path from that instead.
Thanks!
Message 10 of 10
Looks like I just needed a couple minutes to get this done, I posted too soon! Here's the code I used inside compute() in order to get the DAG path of the input mesh on a scripted node.
    def compute(self, plug, dataBlock):
        if plug == self.attrIn_blendWeight:
            multiInputArrayHandle = dataBlock.inputArrayValue( self.attrIn_blendShapeMultiInput )
            fnDNode = om.MFnDependencyNode( self.thisMObject() )
            inputMeshPlug = fnDNode.findPlug( "inMesh", False )
            inputPlugArray = inputMeshPlug.connectedTo(True, False )
            inputNode = inputPlugArray[0].node()
            if inputNode.hasFn( om.MFn.kMesh ):
                fnDAGN = om.MFnDagNode( inputNode )
                meshDagPath = fnDAGN.getPath()
                print "The full DAG Path of the input mesh:", meshDagPath.fullPathName()
                inputMeshFn = om.MFnMesh(meshDagPath)
Now I can move on with my life!
