Announcements
How to check if an render setup layer override is applied to object X?
h.schoenberger
h.schoenberger
Hi
I need to parse all layers and check if an attribute of some objects is set-
As layer overrides can change these values, I need to parse all layers if the override is applied.
So far I have this code to get a list of overrides of all layers:
rs = renderSetup.instance()
rLayers = rs.getRenderLayers()
for layer in rLayers:
    colList= layer.getCollections()
    for col in colList:
        overrides=col.getOverrides()
        for oride in overrides:
            print("override applied to attribute "+oride.attributeName())
But now I need to know if my object is in that layer collection.
I know from the UI interface that you can add objects by its absolute name or by a filter like  *myobj*.
But how do I get this information via script?
cheng_xi_li
Autodesk Support
Autodesk Support
For testing if the object is in a layer you could try renderLayerMembers command like below:
renderLayerMembers "myCylinder" -notIn true -renderLayers "MyRenderSetupLayer"
For collections in renderLayer, I am afraid you'll need to test them yourself. You could get a collection's selector with col.getSelector().
A simpleSelector could get its selection with selection() and it has an iterator path.
Yours,
Li
