polyUVStackSimilarShells command not working?
Craig_Lamorte
Craig_Lamorte
I found this command http://help.autodesk.com/cloudhelp/2018/JPN/Maya-Tech-Docs/PyMel/generated/functions/pymel.core.mode...
I am just doing pm.polyUVStackSimilarShells() - but its not working. - # Error: AttributeError: file <maya console> line 6: 'module' object has no attribute '' #
How do I get this command to work?  Or is there a similar command?
sean.heasley
Hi @Craig_Lamorte
We don't officially support pymel but that said I found this thread that may help you out!
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Craig_Lamorte
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
