OpenVDB for Maya 2106.sp6:
Message 1 of 1
Hello there,
I've build OpenVDB 4.0.1 with the instruction provide by 'BuildingWithCMake.md' in the package.
I'm using this configuration for cmake and all want fine:
export ILMBASE_ROOT=/prod/softprod/libs/openexr/2.2.0
export OPENEXR_ROOT=/prod/softprod/libs/openexr/2.2.0
export GLFW3_LOCATION=/prod/softprod/libs/glfw/3.2.1
export MAYA_LOCATION=/prod/softprod/apps/maya/2016.sp6/linux
export BLOSC_LOCATION=/prod/softprod/libs/c-blosc/1.7.1
export TBB_ROOT=$MAYA_LOCATION
export BOOST_ROOT=/prod/softprod/libs/boost/1.61.0
export LD_LIBRARY_PATH=$BOOST_ROOT/lib:$ILMBASE_ROOT/lib:$OPENEXR_ROOT/lib:$GLFW3_ROOT/lib:$BLOSC_ROOT/lib
cmake \
-D CMAKE_BUILD_TYPE=Release \
-D CMAKE_CXX_COMPILER=/opt/rh/devtoolset-2/root/usr/bin/g++ \
-D CMAKE_C_COMPILER=/opt/rh/devtoolset-2/root/usr/bin/gcc \
-D CMAKE_CXX_FLAGS=-std=c++11 \
-D BLOSC_LOCATION=/prod/softprod/libs/c-blosc/1.7.1 \
-D Tbb_TBB_LIBRARY=$MAYA_LOCATION/lib/libtbb.so \
-D Tbb_TBBMALLOC_LIBRARY=$MAYA_LOCATION/lib/libtbbmalloc.so \
-D OPENVDB_ENABLE_3_ABI_COMPATIBLE=ON \
-D OPENVDB_BUILD_UNITTESTS=OFF \
-D OPENVDB_BUILD_DOCS=OFF \
-D OPENVDB_BUILD_MAYA_PLUGIN=ON \
-D OPENVDB_ENABLE_RPATH=ON \
-D ILMBASE_NAMESPACE_VERSIONING=OFF \
-D OPENEXR_NAMESPACE_VERSIONING=OFF \
-D USE_GLFW3=ON \
-D GLFW3_LOCATION=/prod/softprod/libs/glfw/3.2.1 \
-D Boost_USE_STATIC_LIBS=ON \
-D Blosc_USE_STATIC_LIBS=ON \
-D CPPUnit_USE_STATIC_LIBS=ON \
-D CMAKE_INSTALL_PREFIX=/prod/softprod/libs/openvdb/4.0.1 \
make
make install
But when i try to load the OpenVDB.so plugin, it failed with an error:
/prod/softprod/libs/openvdb/4.0.1/maya2016/plug-ins/OpenVDB.so: undefined symbol: _ZNK7MPxNode9dependsOnERK5MPlugS2_Rb //
// Error: line 1: /prod/softprod/libs/openvdb/4.0.1/maya2016/plug-ins/OpenVDB.so: undefined symbol: _ZNK7MPxNode9dependsOnEdevRK5MPlugS2_Rb (OpenVDB) //
I'm on Centos 6.8. I'm using devtoolset-2 (gcc 48.2).
I don't know where to search for resolving this error...
Can you help me please.
Thank
Replies (0)
