Unlocking attributes via python
Craig_Lamorte
Craig_Lamorte
How would i go about unlocking translate, rotate, scale if they have been locked (like if you right click them in channel box and click lock.  There will be a gray box surrounding that attribute when locked)
I have been trying to find out how to do it myself without much success.  The closest I have gotten was doing this command
pm.setAttr('poly.translate', lock=False)
So this command did not work unlocking the attributes when I had locked them in the channel box through the UI.  The only way that command will work is if lock it by running the command with lock=True first...  Which is not very useful if it only unlocks it under certain conditions.
I cannot find any command that will unlock them after locking them through the channel box ui.
Craig
The problem you are encountering is that you are trying to unlock translate and not translateX, translateY, and translateZ all separately.
I typically build a list of axis
axis = ['X', 'Y', 'Z']
and a list of transform attrs
attrs = ['t', 'r', 's']
and then run a nested for loop to unlock all of them.
for ax in axis:
    for attr in attrs:
        cmds.setAttr(obj+'.'+attr+ax, lock=0)
which basically ends up with
cmds.setAttr(obj+'.tX', lock=0)
etc
Craig_Lamorte
awesome that totally worked! thanks!
guess it doesn't like when i use just translate / scale / rotate to grab all 3
Craig_Lamorte
**edit - nevermind its working now, not sure why it wasn't working in the first place
One more question...  Trying to query whether the attribute is locked or not.  I tried this -
cmds.getAttr(obj+'.tx', lock=True)
 But all i am getting his False no matter if its locked or not...
morten_bohne
This works for me:
import maya.cmds as cmds
objs = cmds.ls(sl=True)
for obj in objs:
    attrs = cmds.listAttr(obj)
    for attr in attrs:
        try:
            if cmds.getAttr("{0}.{1}".format(obj, attr), lock=True) == True:
                print "{0}.{1} is Locked".format(obj, attr)
            else:
                print "{0}.{1} is unlocked".format(obj, attr)
        except ValueError:
            print "Couldn't get locked-state of {0}.{1}".format(obj, attr)
Or to unlock all attributes on selected objects in pymel:
import pymel.core as pm
for obj in pm.selected():
    for a in pm.listAttr(obj):
        obj.attr(a).unlock()
shorter, faster but less readable:
[obj.attr(a).unlock() for a in pm.listAttr([obj for obj in pm.selected()])]
p.ivanov2KWFH
Observer
Observer
your code was not completely correct
I've refined it a little)
axis = ['x', 'y', 'z']
for ax in axis:
    for attr in attrs:
    	for obj in objs:
