MFnAnimCurve.getTangent signature change from 2017 to 2018
Hey all,
So, apparently the function signature for Snippet
MFnAnimCurve.getTangent(
has changed from float to double.
Thus breaking a number of methods I've been working on. I'd rather not have to regenerate new projects for these methods, specific to 2018.  Is there a recommended work-around for this?
cheng_xi_li
Autodesk Support
Autodesk Support
Are you using .Net? If you would like to fix the compiling errors without modifying original code, you could try extension methods.
e.g.
using Autodesk.Maya.OpenMaya;
using Autodesk.Maya.OpenMayaAnim;
//Enable it if it is compiling for Maya 2018
using MFnAnimCurveExtension;
namespace MFnAnimCurveTest
    public class CompilerTest
        public void doIt(MObject obj)
            float x = 0;
            float y = 0;
            var fn = new MFnAnimCurve(obj);
            fn.getTangent(0, ref x, ref y, true);
namespace MFnAnimCurveExtension
    public static class MFnAnimCurveExtension
        public static void getTangent(this MFnAnimCurve curve, uint index, ref float x, ref float y, bool inTangent)
            double _x = 0;
            double _y = 0;
            curve.getTangent(index, ref _x, ref _y, inTangent);
            x = (float)_x;
            y = (float)_y;
Hope it helps.
Yours,
Li
I think I'm good with this.
Feels a lot cleaner than going about building out a bunch of #if/#else/#endif cases.
I'll give it a go, and accept the solution if it works for me.
