Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
(MEL)getting curve cv parameter?
absoluteKelvin
absoluteKelvin
 string $selected[] = `ls -sl`;
 string $shapes[];
 float $uParam[] ;
 for ($curve in $selected){
    int $CVs =`getAttr ($curve + ".spans")`;
    $shapes = `listRelatives -shapes $curve`;
    string $nearestInfo = `createNode nearestPointOnCurve`;
    connectAttr ($shapes[size($shapes)] + ".worldSpace") ($nearestInfo +".inputCurve");
    for ($x = 0; $x < $CVs; $x++)
        vector $location = `pointPosition ($curve + ".cv[" + $x + "]")`;
        setAttr ($nearestInfo + ".inPositionX") ($location.x);
        setAttr ($nearestInfo + ".inPositionY") ($location.y) ;
        setAttr ($nearestInfo + ".inPositionZ") ($location.z) ;
        $uParam[$x] = `getAttr ($nearestInfo + ".parameter")`;  //format getAttr nearestPointOnCurve1.parameter;
        string $Parameter = $uParam[$x];
        print ($Parameter + "\n");
    delete $nearestInfo;
this is the code i came up with after reading up on documentations and help from sites https://nccastaff.bournemouth.ac.uk/jmacey/RobTheBloke/www/mel/DATA_ncurve.html
http://download.autodesk.com/global/docs/maya2012/en_us/Nodes/nearestPointOnCurve.html
Currently it works on one curve. But Its suppose to work for multiple curves.  When I run it it gives me
// Error: line 9: The source attribute '.worldSpace' cannot be found. //
https://www.artstation.com/kelvintam
stuzzz
looking at Nurbs shape output attributes in maya2018, worldSpace attribute is an array.
so you may explicitly specify an index to worldspace ( ie. worldspace[0] )
connectAttr ($shapes[size($shapes)] + ".worldSpace[0]") ($nearestInfo +".inputCurve");
absoluteKelvin
i edited the code with your suggestion, but this occurs when i have 2 curves selected.
// Error: line 9: The source attribute '.worldSpace[0]' cannot be found. //
absoluteKelvin
i found the issue. d'ohhh its the shapes[size($shapes)] thats causing issues
with this it will work regardless even without .worldSpace[0]
connectAttr -force ($shapes[0] + ".worldSpace") ($nearestInfo +".inputCurve");
stuzzz
great!
