Increase size of Render Targets (4k+)
Hey everyone,
Is there a way to create render targets larger than 4K? Maya is capping my render targets at 4096px... Maybe there is a setting I am missing?
I am using such big resolutions for DSR/Supersampling purposes.
thanks and regards,
Santiago.
cheng_xi_li
Autodesk Support
Autodesk Support
Hi thasanty,
Please add MAYA_VP2_USE_GPU_MAX_TARGET_SIZE to your system environment. It will allow Maya use the max gpu texture size as your render target size. You can find it in the output window.(e.g. Max texture size : 16384 * 16384 )
Yours,
Li
Awesome!
Thank you Li, this solved my problem
all the best,
Santiago
