How do I can create those draggable/slider like input widgets?
Good Evening,
I am wondering if I can create those slider like input widgets which are used in Maya very often. Everytime I am searching for something like that google shows me how to make drag and drop widgets, what I DONT want to do.
Here is a picture of those widgets inside maya:
So does anyone know how they are called and how they were made, especially for python?
Regards
You can use maya.cmds.intField ( or floatField / textField ) :
import maya.cmds as cmds
cmds.window(title='My Window') cmds.columnLayout() cmds.rowColumnLayout(numberOfColumns=2) cmds.text('intField') cmds.intField('intField1', v=10, min=1, max=10) cmds.showWindow()
Or with Qt it's called a QSpinBox
https://srinikom.github.io/pyside-docs/PySide/QtGui/QSpinBox.html
Thanks for your reply. The QSpinBox wasn't really what I was thinking of. Or I haven't figured out how to do. That's why I made my custom QT widget. Everyone can use it but please don't remove the credits,it took a while to program:
If someone finds any bugs let me now!
class QSlideInput(qw.QLineEdit):
    """own implementation of the maya's slide input widget
    # Date: 23.09.2016
    # Author: LifeArtist"""
    # an public event you can bind to from outside
    # and which notifies if the value has changed or not
    valueChangedEvent = qc.Signal()
    def __init__(self, *args, **kwargs):
        qw.QLineEdit.__init__(self, *args, **kwargs)
        self.init()
        self.initUi()
    def init(self):
        self.dragFlipped = False
        # how many pixels you have to move the mouse to increse or decrease
        # the value
        self.incdecSteps = 4
        self._currentStep = 0
        self.lastCoordValueX = 0
        self.dragBeginCount = 9
        self._dragCurrentCount = 0
        # value which will be added or substracted
        self.incdecrementor = 1
        self.lastMousePressedPos = qc.QPoint()
    def initUi(self):
        self.canSetFocusOnInput = True
        self.setFocusPolicy(qc.Qt.NoFocus)
        self.returnPressed.connect(self.clearFocus)
        self.setCursor(qc.Qt.SplitHCursor)
        self.setMouseTracking(0)
        self.setText("0.0")
        self.setValidator(qg.QDoubleValidator())
    def mouseMoveEvent(self, event):
        if not self.hasFocus():
            # | enables drag events |
            if self._dragCurrentCount == self.dragBeginCount:
                self.on_dragEnter()
            if self._dragCurrentCount >= self.dragBeginCount:
                self.on_drag()
            self._dragCurrentCount += 1
    def mousePressEvent(self, event):
        self.setMouseTracking(1)
        self.lastMousePressedPos = qg.QCursor.pos()
        self.lastCoordValueX = qg.QCursor.pos().x()
    def keyPressEvent(self, event):
        return super(QSlideInput, self).keyPressEvent(event)
    def mouseReleaseEvent(self, event):
        """function will be called if the mouse was released"""
        # if the mouse was released we need to put the mouse to its last pos
        qg.QCursor.setPos(self.lastMousePressedPos)
        if self.canSetFocusOnInput:
            self.setFocus()
        else:
    def on_dragEnter(self):
        """function will be called if the mouse was hold down for the amount
        of dragBeginCount"""
        self.canSetFocusOnInput = False
        self.setCursor(qc.Qt.BlankCursor)
    def on_drag(self):
        """function will be called everytime you drag your mouse but first
        after on_dragEnter"""
        currentX = qg.QCursor.pos().x()
        if self.incdecSteps == self._currentStep:
            # | check whether strg, shift is pressed or none |
            modifiers = qw.QApplication.queryKeyboardModifiers()
            if modifiers == qc.Qt.ControlModifier:
                self.incdecrementor = 0.1
            elif modifiers == qc.Qt.ShiftModifier:
                self.incdecrementor = 10
            else:
            # | addition and substraction logic |
            currentValue = float(self.text())
            # determinds if its incremented or decremented
            if self.lastCoordValueX < currentX:
                currentValue += self.incdecrementor
            elif self.lastCoordValueX > currentX:
                currentValue -= self.incdecrementor
            # sets the new text
            self.setText(str(currentValue))
            # emit event
            self.valueChangedEvent.emit()
            self.lastCoordValueX = currentX
        else:
            self._currentStep += 1
        # reset the cursor if it reaches the end of the screen
        desktopWidth = qw.QApplication.desktop().availableGeometry().width()
        if currentX == (desktopWidth - 1):
            qg.QCursor.setPos(0, qg.QCursor.pos().y())
        elif currentX == 0:
            qg.QCursor.setPos(desktopWidth - 1, qg.QCursor.pos().y())
Life
