How to reorder vertices index according to white object in Maya 2013 by mel?
janekanFZ5GL
janekanFZ5GL
sean.heasley
Hi @janekanFZ5GL
We have an article on how to do this you can find here!
That said, I'm not 100% sure if it will work in Maya 2013 as we no longer support it.
sean.heasley
Hi @janekanFZ5GL
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
janekanFZ5GL
Thanks your reply!
But I can't find the command "Reorder Vertices" in Maya 2013.
I found another way to do it.
Thanks again.
mspeer
Hi!
This was added in Maya 2017.
sean.heasley
Hi @janekanFZ5GL
Glad you figured it out!
Would you mind posting what you did to fix this? It could be helpful to any other users using older versions of Maya that may run into the same problem!
