How to log the Frame Rate that is displayed
legoman2015
Observer Observer
legoman2015
Observer
Observer
In the menu to display the Frame Rate:
Display-> Heads Up Display -> Frame Rate
Is there a way to log the Frame Rate to a file?
tony.su
Autodesk Support
Autodesk Support
I guess you should make an api plug-in for it.
Tony Su
Product Support
Not sure how you would you do that so that the frame rate goes to the API?
tony.su
Autodesk Support
Autodesk Support
I guess you can got this from API and then export it into a file.
But I don't know how to do it.
Tony Su
Product Support
