How do you use kwargs within OpenMaya api v 2.0?
jwlove
Message 1 of 8
jwlove
I've recently become aware of the python OpenMaya api v2.0, so I've been going through my code and trying to update it to use the 2.0 version. For the most part it has made a lot more sense to me than the older version of OpenMaya...
I've run into a snag while trying to use the OpenMaya.MFnNurbsSurface.closestPoint method. I can't seem to figure out how to actually use the kwargs for the method. Maya's docs say this:
closestPoint(testPoint, uStart=None, vStart=None,
    ignoreTrimBoundaries=False, tolerance=kPointTolerance,
    space=kObject) -> (MPoint, float, float)
So to me, that looks like kwargs that I should be able to use... but I get errors just about every time I try to use them - and when it doesn't error, I don't really understand why it didn't (examples below). If I don't put in the kwargs, it 'works' but doesn't give me the correct results since I actually do need to change some of those kwargs.
Here's some code of the old and new way of doing this (the new is just what I have so far...):
import maya.OpenMaya as oldOM
import maya.api.OpenMaya as om
def getClosestPointOnSurfaceOLD(surf, position):
    selList = oldOM.MSelectionList()
    selList.add(surf)
    mDagPath = oldOM.MDagPath()
    selList.getDagPath(0, mDagPath)
    surfFn = oldOM.MFnNurbsSurface(mDagPath)
    u_util = oldOM.MScriptUtil()
    u_util.createFromDouble(0)
    u_param = u_util.asDoublePtr()
    v_util = oldOM.MScriptUtil()
    v_util.createFromDouble(0)
    v_param = v_util.asDoublePtr()
    p = surfFn.closestPoint(oldOM.MPoint(*position), False, u_param, v_param, False, 1.0, oldOM.MSpace.kWorld)
    return [(p[0], p[1], p[2]), (oldOM.MScriptUtil.getDouble(u_param), oldOM.MScriptUtil.getDouble(v_param))]
def getClosestPointOnSurfaceNEW(surf, position):
    selList = om.MSelectionList()
    selList.add(surf)
    surfFn = om.MFnNurbsSurface(selList.getDagPath(0))
    p, u, v = surfFn.closestPoint(om.MPoint(*position), ignoreTrimBoundaries=False, tolerance=1.0, space=om.MSpace.kWorld)
    return [(p[0], p[1], p[2]), (u, v)]
I've tested it by creating a nurbsPlane (with defaults) and then moving it up 0.5 units in y and comparing the output of the two functions with these lines:
getClosestPointOnSurfaceOLD('nurbsPlane1', (0.0, 1.0, 0.0))
# Result: [(-2.7755575615628914e-17, 0.5, 2.7755575615628914e-17), (0.5, 0.5)] #
getClosestPointOnSurfaceNEW('nurbsPlane1', (0.0, 1.0, 0.0))
# Error: TypeError: file <maya console> line 28: integer argument expected, got float #
Other things I've tried to do with the 'closestPoint' line in my function:
surfFn.closestPoint(om.MPoint(*position), ignoreTrimBoundaries=False)
# Result: [(-2.7755575615628914e-17, -1.5407439555097887e-33, 2.7755575615628914e-17), (0.5, 0.5)] #
surfFn.closestPoint(om.MPoint(*position), False)
# Result: [(-1.1102230246251565e-16, -6.162975822039155e-33, 1.1102230246251565e-16), (0.5, 0.5)] #
surfFn.closestPoint(om.MPoint(*position), tolerance=1.0)
surfFn.closestPoint(om.MPoint(*position), tolerance=1)
# Error: RuntimeError: file <maya console> line 28: More keyword list entries (6) than format specifiers (5) #
surfFn.closestPoint(om.MPoint(*position), 1.0)
surfFn.closestPoint(om.MPoint(*position), space=om.MSpace.kWorld)
surfFn.closestPoint(om.MPoint(*position), om.MSpace.kWorld)
surfFn.closestPoint(om.MPoint(*position))
surfFn.closestPoint(om.MPoint(*position), False, 1.0, om.MSpace.kWorld)
# Result: [(-2.7755575615628914e-17, 3.851859888774472e-33, -6.938893903907228e-17), (0.5, 0.5000000000000001)] #
surfFn.closestPoint(om.MPoint(0.0, 1.0, 0.0), uStart=0.0, vStart=0.0, ignoreTrimBoundaries=False, tolerance=1.0, space=om.MSpace.kWorld)
surfFn.closestPoint(om.MPoint(0.0, 1.0, 0.0), 0.0, 0.0, False, 1.0, om.MSpace.kWorld)
Some of the differences in output is just strange to me, and the errors don't seem to make sense (like the differences when adjusting the 'tolerance' arg value)... Also, it turns out that the uv values of 0.5 being correct is just coincidental - if I move and/or rotate the plane, the old function returns different uv values while the new function always returns 0.5 since it's evaluating the test point from the plane's object space instead of using world space.
I also took a look at the docs for the corresponding old OpenMaya command where there were two entries - one of which has a 'paramAsStart' boolean arg to use if you are going to provide some start uv values. Thinking the 2.0 docs may have missed that, I tried adding that into my api 2.0 attempt too... It didn't work either (gave me an error that I passed in too many args).
For the bare minimum, I need to figure out how to make it evaluate the test point from world space; However, as I continue using the OpenMaya api 2.0, I'm sure I'll run across this type of thing again - any help on how to actually use these kwargs is appreciated!
Replies (7)
Message 2 of 8
cheng_xi_li
Autodesk Support
Autodesk Support
It looks like the same issue with anyIntersection. I'll make an update to that issue and let our engineers aware of it.
Update: I've just check the system, it is a known issue and our engineers are working at it.
Yours,
Li
Message 3 of 8
jwlove
oh, thank you!  I thought I was going crazy and was just starting to look into how to submit a bug report...  Any idea how long it would take to get this fixed?  Also, would it be available for Maya 2017, or just future versions?
Message 4 of 8
cheng_xi_li
Autodesk Support
Autodesk Support
Sorry I don't know when it is going to be fixed. It might not be available in Maya 2017.
Yours,
Li
Message 5 of 8
zapan669
Still there in Maya 2018,  this kind of Bug is important and should be fixed now !
Message 6 of 8
zapan669
Well, I see your frustration but I have to defend Maya a bit.
Actually I still believe it’s the best 3D software. The core is solid, MEL works great to do what it is supposed to do (control Maya with strings). And the API is simple but globally works great at 99%. Globally te software is a solid base on any production in movie or video game.
Of course I’m not happy when I find this kind of bug. But honestly if I’m still on Maya today there is a reason, and don’t talk to me about Houdini I heard that 20 times and it’s not true, it lacks of a lot of things and will require years to be at the same level.
Message 7 of 8
zapan669
Not working in Maya 2018 update 4,     what about 2019 and 2020 ?
Message 8 of 8
cheng_xi_li
Autodesk Support
Autodesk Support
I've just tested with Maya 2019.3 and Maya 2020.1, it should be fixed in both of them.
Yours,
Li
