How can I perform a modulus(%) operation inside node editor?
As the title says, and no coding please, but an expression is ok though_(:з」∠)_
mspeer
Hi!
fmod
well, I didn't find such node in 2018, maybe it has been removed?
I already wrote some expressions instead though_(:з」∠)_
mspeer
Hi!
"fmod" is the MEL command you can use in an expression.
Oh, I didn't know, but I use the operator "%" more often. I didn't know how to write an expression, so, no more problems_(:з」∠)_
monkeyloo
Maya really should add an modulus utlility now though, I could use that.
I found an external plugin on github but I am not allowed to use external plugins for my current project.
