Get renderLayer override attr values?
Hello, anyone knows how to do just that?
Say I want to get the per render layer render frame range of all my different render layers (that have been set with overrides).
How can I do that *without actually changing currently active layer*, using Mel, Python or PythonAPI?
cheers
fred
burgeso
Try this MEL script; the procedure will list the overrides for each one of your render layers:
global proc renderLayerDiagnose()
int $currentLayer = `getAttr renderLayerManager.crl`;
string $renderLayers[] = `listConnections -destination 1 -source 0 -plugs 0 renderLayerManager.renderLayerId`;
for ($rl=0; $rl < `size($renderLayers)`; $rl++)
int $id = `getAttr ($renderLayers+".identification")`;
if ($id == $currentLayer)
// do your own thing here....
// e.g. this block prints out the overrides that apply to the current layer
string $overrides[] = `listConnections -destination 0 -source 1 -plugs 1 ($renderLayers+".adjs")`;
int $index, $overridesSize;
$overridesSize = `size($overrides)`;
if ($overridesSize!=0)
for ($index=0; $index < $overridesSize; $index++)
print ($overrides + "\t");
print `getAttr ($renderLayers+".adjs.value")`;
print "\n";
else print ("No overrides on "+$renderLayers+"\n");
Owen
Mayastation
Owen Burgess
Maya Support Specialist
Product Support
Autodesk, Inc.
Hi Owen,
and and thanks so much for that mel script, that is really very helpful!! 🙂
I hope you didn't write it just now!?
That should be plenty for me to figure out how to do what I want!
thanks again
fred
