Check object type?
Check object type?
Check object type?
my problem is really simple.. i need to know witch type is my selected object.
Actually i do something like:
selList = OM.MSelectionList()
OM.MGlobal.getActiveSelectionList( selList )
selListIter = OM.MItSelectionList( selList )
while not selListIter.isDone():
dagpath = OM.MDagPath()
component = OM.MObject()
dagnode = OM.MFnDagNode()
selListIter.getDagPath( dagpath, component )
dagnode.setObject( dagpath )
# check type of object selected
# if POLYGON: do something
# if LOCATOR: do something
selListIter.next()
how can I check if what I select is a Locator or a Polygon?
(to simplify the problem i can check just one of them and with an IF-ELSE statement i can continue by myself)
can't anyone help me?
I really need some suggestions..
Hello, I've been codding python in maya for a while, and its quiet messy.
The thing is... I don't know what library you are using, but my best guess is how to use it with the basic maya.cmds.
By the way thanx for posting it, I've learned more of maya python in the process, so be my guest and post things like this, as many as you can.
You helped my develop a new very usefull tool!
Ok my interpetation of what I said is this, tell me if it helped:
impot maya.cmds as mc
#get the list of selected objects, will only return the transform nodes
sel=mc.ls(sl=True)
#iterate list of selectd objects
for i in range(0,len(sel),1):
#this is for clarity you could have gone with sel insted of curr objects
currObj=sel
#selecte each item's hierarchy
mc.select(currObj,hi=True)
#from this selction, keep only the first shape node
currShape = mc.ls( sl=True, shapes=True)
print currShape
#print the shape and its type, for clarity as well
print mc.ls(currShape,showType=True)
#compare the type of shape that it is
if(mc.objectType(currShape, isType="locator")):
print currShape+" is a locator "
elif(mc.objectType(currShape, isType="mesh")):
print currShape+" is a Mesh"
#if it is neither a locator nor a mesh, i don't know what it is
else:
print "No idea of the type of the damned shape"
print"\n-------------------------"
#return to inicial conditions of selection
mc.select(sel)
I hope my explanationts in the code are helpfull for you, else tell me and I'll be happy to explain my self further
haggi
If you have an MObject, you should be able to test for a type with:
import maya.OpenMaya as om
mobject....
if mobject.apiType() == om.MFn.kMesh:
print "its a mesh"
if mobject.apiType() == om.MFn.kLocator:
print "its a locator"
haggi
Maybe you allow me to show some examples how to use pymel and make code more efficient.
Your original was (I removed the comments):
sel=mc.ls(sl=True)
currObj=sel
print currShape
else:
mc.select(sel)
I think with pymel you can do this:
import pymel.core as pm
for object in pm.ls(sl=True):
shape = object.getShape()
if shape.type() == "mesh":
print "Its a mesh..."
Wow, that's cool i'll try that, thanx.
Where can I get the api of pymel?
