How to get reference file when it is not correctly loaded?
I have a maya scene made in windows and opened in linux, obviously it can't find it's reference as it uses absolute path. In order to correct it, firstly, I need to know the original file path such as 'Z:\model\model.mb', so that I can look for model.mb and get its path in linux. I use commands below:
string $allrefs[] = `file -q -r`;
But it seems this line only works when reference is successfully reached, if maya can not find the reference file, it returns nothing.
burgeso
Even if the reference file wasn't found at the given path, the reference node (that stores the reference edits) will still be created in your scene. Querying this reference node will return the path of the associated file:
referenceQuery -f cubeRN;
// Result: C:/cube.ma
Hope that helps,
Owen
Owen Burgess
Maya Support Specialist
Product Support
Autodesk, Inc.
Firstly, thanks a lot. I have been waitting this reply for a long time 🙂
I have tried this, but it does not seem to be working.
referenceQuery -f FaSheChangRN;
// Error: Reference node 'FaSheChangRN' is not associated with a reference file. //
Hope that helps,
Owen
Yeah, that's right, it has the reference node, but not the 'filename' attribute.
PS: I'm using maya2011 for linux
Hope that helps,
Owen
Oh,this doesnt work,who can help me?I'am going mad 🙂
And this problem is also with cache file, i.e.you never know it's original path unless maya has loaded it correctly.
