Get local path from path with references
Hello.
I have a maya file that references another maya file.
DAG path strings look like this:
|root_skeleton|rig:Geometry|rig:skeleton_effects|rig:skeleton_effectsShapeOrig
I can obtain the namespace which is ":rig".
Now I need to get the local path for a node within referenced file, e.g.
|Geometry|skeleton_effects|skeleton_effectsShapeOrig
The easy but dirty approach is to transform ":rig" => "rig:", then delete everything before first namespace occurance and finally delete the remaining namespace substrings.
But I wonder is there a Maya API to get the local path without namespace in a cleaner way?
olarn
http://help.autodesk.com/cloudhelp/2018/ENU/Maya-SDK/cpp_ref/class_m_namespace.html#a3d06313c5ef9f98... 🤔
edit:
Ah, long name is not supported. Python regex is still the simplest solution.
Yeah it seems to be stripping all path component except for the last one. Thanks for clarifying that replacing is OK-ish solution.
