Export fbx triagulate python
vuhoangtuandct
vuhoangtuandct
Im running into a problem with this line of code
This code still working
Location = .... ( my Computer path)
Mel.oval('FBXExport -f "{0} -s'.format(location))
This still working too (export highpoly mesh)
Mel.oval('FBXExport -f "{0} -s FBXExportSmoothingGroups -v true'.format(location))
But as soon as i add this option
Mel.oval('FBXExport -f "{0} -s FBXExportTriagulate -v true'.format(location))
It's still working but not triagulate the mesh aa i want
Please help me. Thank you guys !
Hello @vuhoangtuandct ,
Hope you're doing fine.
The below command works for me in maya 2024 and 2020 in windows 10
document that i referred - https://help.autodesk.com/view/MAYAUL/2024/ENU/?guid=GUID-6CCE943A-2ED4-4CEE-96D4-9CB19C28F4E0
import maya.cmds as cmds
import maya.mel as mel
path = "D:/All_Projs/Maya_Projs/tri.fbx" # forward slashes are important
mel.eval('FBXExport -f "{0}" -s FBXExportTriagulate -v true'.format(path))
#mel.eval('FBXExport -f "{0}" -s'.format(path))
The command you mentioned
small corrections 🙂
mel.eval('FBXExport -f "{0}" -s FBXExportTriagulate -v true'.format(location))
hope it helps.
A suggestion, kindly next time do provide an error log from the script editor.
