'Create' command in python 2.0 API?
I am trying to create a plugin command in the new Python 2.0 API. The problem is that I cannot find the method asMPxPtr(). Is that method needed and in that case, where is it?
I am asking since I get this error when not using it:
Error: RuntimeError: file <string> line 2: Failed to convert result of script creator function
this is when returning an instance of my MPxCommand derived class (as described in the docs):
createCmdFunc is a Python callable which takes no arguments and returns a new instance of the MPxCommand-derived class.
Anyone has any insight into this?
drew_avis
Hi, you don't need to use asMPxPtr() with the 2.0 API.  You can do this in your creator function:
1.0:
# Creator
def cmdCreator():
    return OpenMayaMPx.asMPxPtr( scriptedCommand() )
2.0:
# Creator
def cmdCreator():
    return  scriptedCommand()
def maya_useNewAPI():
    pass
Hope that helps.
Drew Avis
Content Experience Designer
