Announcements
Using pointConstrain manitainOffset?
Hmmm, am I using this correctly?... I can't get that darn Root to snap onto the locator... the offset is still maintained.
locatorRoot = mc.spaceLocator(p = (4,0,0))
mc.rename ('locator1' , 'locatorRoot')
jointRoot = mc.joint ()
mc.rename ('joint1', 'Root')
Root = mc.parent (w = True)
mc.pointConstraint ('locatorRoot','Root', mo=False)
Thx!
lee.dunham
locatorRoot = mc.spaceLocator( p = (4,0,0), n='locatorRoot' )
jointRoot = mc.joint( n='Root' )
mc.pointConstraint( locatorRoot, jointRoot , mo=False )
Is that what your after?
There could be something else happening with your code as your expecting the objects orignal names to be correct to rename them.
Your also storing the names on creation in variables, but not using them. Instead try not to rely on names, make use of those variables.
Thanks Lee,
Actually the problem is that the locator is moving , but the locator's pivot is not. How do I move the locator and it's pivot?... I think I need to use the absolute (a) move?...
lee.dunham
hmm the locator shouldn't be moving as your constraining the joint to the locator, not the other way around.
or do you mean that the locator is being created at 4, 0, 0 but the pivot is at 0, 0, 0?
locatorRoot = mc.spaceLocator( n='locatorRoot' )
mc.move( 4, 0, 0, locatorRoot )
Is that more what your after?
