Crash in Maya while using custom DX11 shader in Mayabatch
Message 1 of 1
Hi!
We are trying to create objects in mayabatch.
and Applying our custom directx11 shader.
Our Directx11 shader is based on the sample that is given with the DevKit.
First of all, loading the
ourcustomShader_defaults.mel which is nearly a copy of dx11Shader_defaults.mel create a lot of
Snippet
$gAEAttrPresetCurrentTarget
is not defined
Then when I tried to load ou cusotm shader, our new maps are not loaded.
And then it makes mayabatch crash in the renderer :
  ntdll.dll!KiUserExceptionDispatcher
  ntdll.dll!RtlpUnWaitCriticalSection
  ntdll.dll!RtlEnterCriticalSection
  D3D11.dll!D3D11CoreCreateDevice
  OGSDevices-16.dll!OGS::Devices::IDeviceResource::ReleaseRef
  OGSDevices-16.dll!OGS::Devices::EffectBufferHashMap::ClearAll
  OGSDevices-16.dll!OGS::Devices::EffectCache::~EffectCache
  OGSDevices-16.dll!OGS::Devices::EffectCache::Count
  OGSDevices-16.dll!OGS::Devices::ACacheManager::~ACacheManager
  OGSDeviceDx11-16.dll!OGSInitialize
  OGSDevices-16.dll!OGS::Devices::Sys::Shutdown
  OGSRender.dll!OGSRenderer::uninitializeOGSDevice
  OGSRender.dll!OGSRenderer::~OGSRenderer
  OGSMayaBridge.dll!OGS::Objects::_ListBase<OGSMayaVertexBufferMutator * __ptr64,OGS::Objects::RefCountedLifetime<OGSMayaVertexBufferMutator * __ptr64> >::operator[]
  OGSMayaBridge.dll!OGSMayaBridge::clearOGSMayaRenderer
  OGSMayaBridge.dll!OGSMayaBridge::~OGSMayaBridge
  OGSMayaBridge.dll!OGSMayaBridge::Destroy
  mayabatch.exe!TiteratorWrapperFwd<TmultiIndexDependNodeSet::NodesOfTypeConstIteratorDescriptor,TiteratorWrapper<TmultiIndexDependNodeSet::NodesOfTypeConstIteratorDescriptor> >::operator=
  mayabatch.exe!TiteratorWrapperBidir<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator=
  KERNEL32.DLL!BaseThreadInitThunk
  ntdll.dll!RtlUserThreadStart
If we use the Maya DirectX11 shader, everything is working fine.
So :
- is there any option in MayaBatch to load custom directX11 shader?
- what could cause the renderer to crash in mayaBatch?
I am working in Maya 2017 sp3 on Windows 10
Replies (0)
