BUG MTransformationMatrix.scale()
AdamBakerArt
AdamBakerArt
HI,
Looks like MTransformationMatrix.scale(space) has a bug inside maya that it doesn't return the correct output when trying to get om2.MSpace.kWorld.
Testing in Maya 2022 (windows) and it works as expected but once running in maya 2023 it returns only the local values.
Here is some test code
import maya.api.OpenMaya as om2
import maya.cmds as cmds
# Node name
node = 'cube'
# Lets make a simple cube and put it into a gorup
maya.cmds.polyCube(name=node)
group = maya.cmds.group()
# Scale the group x2
maya.cmds.scale(2,2,2, group)
selection_list = om2.MSelectionList()
selection_list.add(node)
dag_path = selection_list.getDagPath(0)
# Create an MFnTransform object for the node
transform_fn = om2.MFnTransform(dag_path)
# Get the MTransformationMatrix for the node
transform_matrix = transform_fn.transformation()
# Get the scale values in world space
scale_vector = transform_matrix.scale(om2.MSpace.kWorld)
# Print out scale
print('Object Scale in world space:', scale_vector)
Returns:
Object Scale in world space: [1.0, 1.0, 1.0]
Expected Return:
Object Scale in world space: [2.0, 2.0, 2.0]
Not sure if I have totally glossed over something here but it is not working when it comes to getting local scale.
brentmc
On line 22 you are getting the local transformation matrix of the cube, not the world matrix. Try this instead:
transform_matrix = om2.MTransformationMatrix(dag_path.inclusiveMatrix())
P.S. I also tested you script in Maya 2022 and got the same result. Were you testing on the latest update release or an earlier one because I don't think the behaviour of transform_fn.transformation() has changed.
Brent McPherson
Principle Software Developer
AdamBakerArt
Thanks Brent,
You are correct, I was not getting world Matrix, check in with that is going on in Maya 2022 and get back with that information.
I am going to approve your reply and respond with more information.
