I am trying to do the shape 1 with the same silhouette before adding the bevel as u can see i want that shape after extruding but the thing is when i beveled it the curvy edges are not curvy before adding the bevel as you can see in the reference this will be a problem as i am trying do repeat the shape multiple times as it will impact the curvy edges is there any way to avoid this i have attached the ref and the file kindly check on it.
Solved by damaggio. Go to Solution.
You need to fix the topology for this to work. Your image is in smooth mesh mode so it's hard to see the real topology underneath, always post the mesh image in wireframe before Subd.
Here are 2 different options, B has a better topology but A can also work, it's better to put the cut inside a row of faces not centered between 2 rows, that way you gain more sharpness on the cutout part because the edges above and bellow are closer to the cut. ....check the differences. You can also add edge loops on the opening to retain sharper edges if that's what you are going for.
