Hi, I try to do the same as in this video, but at 3:13 when "Outliner" appears, it's not show up in my Maya.
I'm using 2017, the video version is from 2016.
Is that why?
Solved by mspeer. Go to Solution.
Hi, tdHendrix, and thanks for suggestions for help!
No outliner appears in Maya though.
The only other thing I can think of to try is to delete or rename your windowPrefs.mel file and see if it comes back. My windowPrefs file is located here:
C:\Users\yourUserNameGoesHere\Documents\maya\2017\prefs
Try closing Maya, renaming it, and open Maya again so it will create a new one.
You can also try opening the docked Outliner by clicking the button that the arrow is pointing to in this screenshot:
Hi, I tried to rename it but nothing happens when I click Windows > Outliner. I also paste the text but red box appeared.
Also tried to delete WindowPrefs.mel
Hi!
You know that the ("new") Outliner is already open in your screenshot (at the left side of your viewport) ?!?!
If you close it and use Windows > Outliner, it will open again.
More about the interface in Maya Online Help / Documentation.
