Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Unfold3D tells me to clean up non manifold geometry
4 REPLIES 4
2780 Views, 4 Replies
Hello
I'm trying to UV a model of a Jet and Unfold3D keeps telling me I have non-manifold geometry (I don't, I already checked with the cleanup option) and legacy works fine. how can I make it work?
4 REPLIES 4
Christoph_Schaedl
you could try to do a uv projection for the whole object first... sometimes there are nonmanifold uvs...
https://linktr.ee/cg_oglu
brentmc
What result do you get when you select your model and run the following Maya command? (to check for non-manifold 3D/UV geometry)
polyInfo -nmv -nme -nuv -nue
Thanks.
Brent
Brent McPherson
Principle Engineer
Hello, I've been having this issue as well, typing the code in the console returned me the following message:
// Result: polySurface50.e[192] polySurface50.e[955] polySurface50.e[1606] polySurface50.vtx[7] polySurface50.vtx[543] polySurface50.vtx[855:856] polySurface50.e[192] polySurface50.e[955] polySurface50.e[1606] //
How can I fix this issue? Thanks.
brentmc
You need to use Mesh > Cleanup to fix the non-manifold geometry.
See this link for more details:
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Maya/fil...
Cheers!
Brent
Brent McPherson
Principle Engineer
