Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Question poly count
9 REPLIES 9
Message 1 of 10
tori.defelice.221
455 Views, 9 Replies
Question poly count
I have a question on poly count. I have this female model that I want to paint and texture in ZBrush howver the poly count is too high to transfer the ZBrush UV map to the Maya UV map. Any suggestions?
Image is below to show between the two head models.
9 REPLIES 9
Message 2 of 10
The UV map is done in Maya and Zbrush bakes the maps based on that map. After you finish painting just export the maps. This is the same process in Substance or Mudbox.
You might need to watch a few more videos to understand the process and avoid any mistakes down the line .
Message 3 of 10
@damaggio
Do you know or have a beginner tutorial video on UV map baking in ZBrush and exporting the maps to be imported into Maya? or can you show me a video on how to do it?
Message 4 of 10
You can find a lot about this on Youtube, this is very basic.
Message 5 of 10
@damaggio
I look up and down to find a tutorial but I can't find any them that would explain it.
Message 6 of 10
Here's one example...
I would also highly recommend finding a 3D school, you would learn a lot faster having a professional teacher.
Good luck.
https://www.youtube.com/watch?v=yNZNYkqAKSI&ab_channel=AcademicPhoenixPlus
https://www.youtube.com/watch?v=4nVEJtzsM90&ab_channel=AcademicPhoenixPlus
Message 7 of 10
@damaggio
I am falling along on a tutorial. My transfer map is not showing display and search envelope. How would I get that to show up?
Message 8 of 10
Nevermind. I figure it out.
Message 9 of 10
@damaggio
This is what I am not looking for.
 I can't transfers the zbrush uv map onto the maya uv map due to the ploy count being to high. Is there way to lower the zbrush model or the maya model?
Message 10 of 10
I already figure it out. It was the geometry between the two models that was off.
