Announcements
Non-uniform scaling of primitive stretches model UVs
Hello friends
I'm scaling non-uniformly a primitive - cube -  and when I want to UV it's UVs are all stretched.
I had to reinstall Maya and lost my presets for good. I have read the scale maya documentation and tested several settings because this didn't happen before. Axis orientation object or world didn't solve this.
Can you please let me know what setting is incorrect on my scale?
Thank you for your help
faline.custodio.da.silva
@Anonymous
Thanks for posting! Looks like this is functioning as expected.
When you scale a model non-uniform (not with all axis at the same time) the UV's will stretch and you will need to re-uv the model.
Faline Custodio Da Silva
Hey @faline.custodio.da.silva
Thanks for your post.
That's the problem. I re-uvd after I scaled non-uniformly and the resulting UVs is a shown in my above post.
Here's a video if that helps clarify the workflow.
https://drive.google.com/open?id=1Iatt_5A3yRwCIzXYbEysnc95I4I4CSMk
and mb https://drive.google.com/open?id=11pYRSZJQeBSnE5G6bJOKg-If_R7VI-HS
If what I am seeing always happened, all models would have stretched UVs. Is it that maya in my case is not UVing as it should when I apply planar?
Thank you, Sergio
mspeer
Hi!
IF you map from the side, then this is the correct result.
You may try Automatic mapping instead, or use the planar mapping from top and not from the side (rotate Manipulator).
sean.heasley
Hi @Anonymous
@mspeer  has the right idea. Automatic mapping this model and then using Unfold should show better results.
In general non uniform scaling is always going to affect UVs and you really dont want to do anything to the model after UV mapping as it will usually lead to you having to UV map again.
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thanks a lot for your help and @mspeer  and apologies for not getting back earlier but was travelling. Not sure what did it, I re-did what I had done before but it works now. Have a good weekend !
