I need some help figuring out what's going on in my scene. Unfortunately I can't share my scene since it's for a project at work, but I would greatly appreciate any troubleshooting tips any of you might have that I haven't tried yet.
I have a basic character with some shaders applied to it. It's not an especially heavy model, but I noticed that when I try to export any of my objects, Maya would just hang forever on export. So, I tried the following just as a troubleshooting step:
It seems like something's wrong with my scene and not the actual meshes, but I feel like I've checked everything I can think of. I don't know how else to troubleshoot this. Does anyone have any advice on steps I should take to figure it out?
Thanks!
Have you tried to import the scene into a new scene?
Sometimes that does cleanup scenes.
you could try unloading and loading the export files you need in prefs/plugs
delete history and delete unused nodes in file optimize scene file
could be a problem with normals or materials
Thanks for the replies!
@Christoph_Schaedl - I did, but unfortunately it didn't work. I was able to import the entire scene into a new scene, but I still couldn't export anything. I also tried just grabbing everything and exporting as a .mb, but ran into the same issue as when I previously tried to export individual OBJs...
@Ιάσονας - Do you mean like the objExport in the plug-in manager? If so, I did try that but no luck...
Appreciate the suggestions though you guys!
Hi!
Does this only happen with obj exports or also with exports to other file formats (FBX, .ma,.mb)?
What is the last line in the scripteditor history, with "Echo all commands" turned on,when you try to export your scene?
Hi @Kahylan - It happens regardless of file format (obj, fbx, mb, etc.). I hit export and then it just sorta hangs on the spinning wheel... So no error messages or anything like that in the script editor. The last line with echo all commands turned on is just the name I set for the file (example below)
fileOperationsOptionsUICallback ExportActive FileDialogOptionsGrpBoxLayout "C:/Users/[username]/Documents/maya/projects/[project name]/scenes/skinTemp.obj";
