Multi-cut tool doesn't snap to points.
So... I've been using multi-cut tool and it was working fine. I hovered over a point on my polygon object, it snapped and then I clicked on another point, hit enter and boom there's a slice.
But for some reason it doesn't work now. The tool just doesn't snap to those points on my object and when I click with the multi-cut tool, it just creates the point somewhere behind totally out of the object.
I can edit the object in any other way (such as deleting vertices and lines, moving vertices and lines etc.)
Btw. when I created a new polygon cube and tried the multi-cut tool on that cube, it works fine ¯\_(ツ)_/¯, so the problem is with my object.
(for some reason I can't attach the project to this post, it gives me this error: "The attachment's catmodelasd.mb content type (application/octet-stream) does not match its file extension and has been removed.")
What I've tried: resetting multi-cut tool, cleaning up the object, deleting history of the object, restarting Maya, resetting preferences to default, resetting Maya to default (using this tutorial https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...)
Even after that, it doesn't work, do you have any idea, what might be wrong with my object? I attached a short video where I show how it doesn't work.
Did you ever resolve this issue? I am having the same trouble.
brentmc
What happens if you delete history (Edit > Delete By Type  > History) or freeze transformations? (Modify > Freeze Transformations)
As a last resort you can always try resetting your preferences.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Maya-Cus...
Brent
Brent McPherson
Principle Engineer
H97WB
Just adding for anyone having this issue and finding this via google, I fixed mine by exporting the part as obj and importing it again, something obviously went wrong with it under the hood but it's not clear what. Just glad I didn't need to delete my prefs 😂
pvergaraf2
Observer
Observer
Thanks, this worked for me perfectly, literally no other solution worked 😁
