Announcements
Mesh cleanup?
Mesh cleanup?
FalconCrest
Advisor Advisor
Mesh cleanup?
FalconCrest
I need to clean up Zero-Length edges & Degenerated faces.  I have all the vertices on my mesh selected, Mesh > Cleanup toggle on Edges with zero length enter in a value of 1.0 hit cleanup.  I'm expecting a message if there were any zero-length edges cleaned, the script editor doesn't supply much info info other then the options I enabled ? As well can Cleanup, clean degenerated faces ?
_sebastian_f
have you tried selecting your object in object mode first instead of component mode? that should work!
FalconCrest
I originally did select my object in object mode, odd but the good news everything worked perfectly. Thanks 🙂
