Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Modeling
Welcome to Autodeskโ€™s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Maya 2025 "new Bevel" not working - why?
9 REPLIES 9
Message 1 of 10
Alexx31
1156 Views, 9 Replies
my very first test with Maya 2025 and right the first object doesn't work!   ๐Ÿ˜ž
Attached screenshots.
The bevel only affects some edges but not the main edges.
Please explain, thanks
โ€ƒ
โ€ƒ
Tags (2)
9 REPLIES 9
Message 2 of 10
Christoph_Schaedl
in reply to: Alexx31
Its not clear to me which edges you want to bevel?
https://linktr.ee/cg_oglu
Message 3 of 10
Alexx31
in reply to: Christoph_Schaedl
Thanks, but the sharp edges which you can see still sharp in my screenshot. There are the intersections but no rounding. So it did not bevel them.
I added the bevel in object mode (without selected edges) and expected an auto-selection. Did you it differently?
I tested all settings
Message 4 of 10
Alexx31
Bevel works here on my Maya2025 on a cube but not on this shape.
Is it maybe something with the preferences taken from the previous version?
โ€ƒ
โ€ƒ
Message 5 of 10
Alexx31
With new default preferences it's working... but also needs to check "Edges by Angle" in the Attribute Editor.
(Was off by default and is not visible in the channel box)
โ€ƒ
โ€ƒ
โ€ƒ
Message 6 of 10
Alexx31
Great tool, but I still don't understand, why Autodesk didn't go one step further, to make it a procedural modifier.
Similar like you can toggle with key 1 and 3 the smoothing in order to work properly on a lowpoly.
It just has to update the vertex numbers when somesthing is changed at the topology and would allow a non-destructive workflow.
Still the new Maya bevel is way behind Max with its procedural modifier stack โ€“ and the bevel could have been the start to catch up.
Message 7 of 10
jonsX942W
This was broken for me as well. I had to to change these option to fix it , Why would this be not the default?
Message 8 of 10
jonsX942W
Message 9 of 10
jonsX942W
This was broken for me as well. and this did not fix it.
Message 10 of 10
natalyramone
in reply to: jonsX942W
THANK YOU. This fixed it for me, I was getting really frustrated.
