Maya 2017 Extrude Tool Missing Manipulator/Window
Message 1 of 26
I'm seeing some unexpected behavior with the extrude tool in Maya 2017. When I select the face of a cylinder that still has the polyCylinder node as an input, I get the expected manipulator and floating dialogue window with extrusion settings. So far, so good.
If I delete the history of the cylinder, though, I no longer get a manipulator or dialogue window though:
I'm not seeing this problem in Maya 2016. Is this a known problem with 2017, or is there a workaround?
Accepted solutions (3)
Replies (25)
Message 2 of 26
mspeer
Hi!
Here it works with Maya 2017 (without SP1)!
1. Create -> Polygon Primitives -> Cylinder
2. Edit -> Delete by Type -> History
3. Select a face of the cylinder
4. CTRL + E (Extrude)
The option window shows up.
Message 3 of 26
adenne
Previous answer really not helpful at all.
I have a similar issue, I can't see the floating dialogue box at all anymore. Is there an option to turn it on, or had a pref file been corrupted, if so any idea which one.
Message 4 of 26
pshwayka
If the floating box and manipulator are not showing up anymore, it's possible that history is not enabled. You can toggle it on via the little clock icon as shown in the attached. Note: If you don't see the icon, click on those vertical hide/reveal bars that are amongst the icons.
Message 5 of 26
adenne
Hi, thanks for reply, toggling that didn't make a difference.
I deleted the userPrefs.mel and restarted and it came back...bit annoying tbh 🙂
Message 6 of 26
FE-S
When extruding only one direction of the manipulator and the scaling tool are visible, rather than each of the three axes, do you know how i can fix this?
(Construction history is on)
Message 7 of 26
_sebastian_f
disable symmetry if you want the scale handles to show up as well!
Message 8 of 26
FE-S
Thank you very much!
Message 9 of 26
brentmc
Turn off symmetry in the modeling toolkit panel.
In symmetry mode the manip is restricted because modifying the other axes can lead to a non-symmetrical result.
Brent
Brent McPherson
Principle Software Developer
Message 10 of 26
Sorry, but where is the modeling toolkit panel? Im new to Maya.
Message 11 of 26
brentmc
On the right side of the main window there are a couple of vertical tabs that let you switch the panel on the right side of the screen between the channel box, modeling toolkit etc.
Brent
Brent McPherson
Message 12 of 26
I had the same problem. In viewport window Show -> HUD (turn it ON).
Message 13 of 26
... and hotkey T (in default settings) - to show manipulators
Message 14 of 26
Thank you, disabling symmetry helped.
Message 15 of 26
Thank you!
Message 16 of 26
eduardog_m_1993
Observer
Observer
Thanks a lot you solved my ussue in maya 2018
Message 17 of 26
i have the same problem with extrude tool , it simply no't showing nither the axes for extrude nither window
Message 18 of 26
mspeer
Hi!
History
and
In-View Editors (in Heads Up Display)
need to be enabled.
Message 19 of 26
Thank you! Smiley Very Happy
Message 20 of 26
Check to see if Maya has magically Toggled the "In-view Editor" off.
Display -> Heads Up Display -> In-View Editors
Step 1Step 1Step 2Step 2Step 3Step 3
