Maya 2017 Extrude Tool Missing Manipulator/Window
Message 1 of 26
I'm seeing some unexpected behavior with the extrude tool in Maya 2017. When I select the face of a cylinder that still has the polyCylinder node as an input, I get the expected manipulator and floating dialogue window with extrusion settings. So far, so good.
If I delete the history of the cylinder, though, I no longer get a manipulator or dialogue window though:
I'm not seeing this problem in Maya 2016. Is this a known problem with 2017, or is there a workaround?
Accepted solutions (3)
Replies (25)
Message 21 of 26
thanks a lot pshwayka, that freaking history button was the problem, I must have pressed a hotkey without knowing it
Message 22 of 26
HUD being off was my issue, thank you
Message 23 of 26
mihirsbcc
I had the same issue. I created a cube and extruded using the Extrude tool from the self, the widget showed up. Then I went to the model to Bevel, the widget also showed up.
Maya 2020.4
Message 24 of 26
Thank you very much! It helps (:
Message 25 of 26
ginagil91
Community Visitor
Community Visitor
This really helped thank you! My transform component wasn't working either and this fixed it!
Message 26 of 26
GamePaint
Community Visitor
Community Visitor
Rant:
Right...the year is 2023. I had to turn History OFF because Maya crashes so much that I cannot work, EVEN with autosave on every 5 minutes, because I will literally lose my work still.
So, without History, you lose critical modelling options and utility. With History, you lose what you just made because it makes Maya puke within a very short time frame. Chapeau!
History often rhymes they say, it certainly does with Maya.
Crash, crash, crash
Pay some cash
Another useful crash
