How to mirror rotation on a duplicated object
User mirrored rotation on a duplicate object by grouping and inputting negative values tried to follow but couldn't replicate, could someone help me out step by step?
1. Group object 1 -0:19
2. Duplicate group
3. Select group 2 (not the object) in the channel box, input negative value in scale to the corresponding axis you want to mirror in -0:29
4. SHFT select over both objects and rotate
If that's not working you have to center the pivot as it's the rotation point
If you want to add a Center pivot shortcut to a shelf tab
1. Paste this Center pivot script      xform -ws -a -piv 0 0 0;
    into the script editor under the MEL tab
2. Highlight pasted script, RMB click + drag to shelf
3. A popup will appear, choose MEL
To change icon
1. LMB over new shortcut> edit
2. In the shelf editor> shelves> Next to Icon name click on the folder icon, choose desired icon
Same steps to mirror rotation with an extra step
1. Group object 1
2. Duplicate group
3. Select group 2 (not the object) through the outliner, in the channel box input negative value in scale to the corresponding axis you want to mirror in
5. Center pivot, rotate
Don't Forget to reset the Rotation Tool settings before doing the steps
