Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
How do I fix an edge I forgot to bevel?
2 REPLIES 2
snpapa
473 Views, 2 Replies
I'm working on a Lego man model and while I was adding bevels to the leg I accidentally missed an edge, and I only noticed now so I can't undo it. How can I go about fixing this problem?
2 REPLIES 2
snpapa
in reply to: snpapa
pls help I try to bevel it and my verts say haha no we don't work
brentmc
in reply to: snpapa
You could use Mesh > Mirror to mirror the good side of the model to the bad side.
Depending on your needs you could mirror the whole object or cut out the bad part and just mirror that. (in which case you would also need to use Edit Mesh > Merge to reconnect the new faces)
Maya Help: Mirror Options
https://help.autodesk.com/view/MAYAUL/2020/ENU/?guid=GUID-E66AE3D8-3B9C-4D4E-9A3E-5BDAFCD67F1D
Brent
Brent McPherson
Principle Engineer
Technology Administrators
