Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have many objects and their childrens in my scene (around a thousand) and I need to rotate their pivot in 90 degrees in one direction so that the Z axis is pointing forward instead of the X axis.
When I select them, enter the pivot mode and rotate them all in 90 degrees, all their pivots are pointing in one direction which is undesired and I think its a defect.
How can I select all the objects and rotate their pivots in a relative way to each object by 90 degrees so that the Z axis of each object is pointing forward instead of the X axis?
