Why the **** triangles?!?!
HEY!
I wanna know, I NEED to know.
What kind of accasion should i use the "Triangulate Faces"?????? It just add useless edges, get bigger the archieve and is a **** to remove if you need.
Maybe I just can't see the 'good side' of triangles. If someone knows... 😄
One time would be when using 'Type' to make text. Type makes 3d text but the topology on front and rear faces are not complete (not even started I guess). If you triangulate the type it will then render properly.
