Where can i get an old 32 bit maya version ?
Hello guys,
I need your help.
We are making a game with the Source Engine from Valve (counter-strike, half-life etc.)
The exportation plugins don't work with a 64 bit versions of Maya.
So we are searching an old 32 bit version of maya (2007-2012).
Do you know where i can dowload it ?
Thx a lot
mspeer
Hi!
Such old versions are no longer available.
Even if you could get one, there are 2 more problems:
- get it running on a modern OS
- activating the software
there must be a solution
mspeer
Hi!
You can write you own exporter for Maya.
(I remember that I did this for Warcraft 3 as there was only an exporter for a very old 3ds Max version available)
This may take some time, but it gives you full control and you can adapt anything to your needs.
This also enables you to use all the new tools of current Maya versions.
I thank you for the post, it is very informative.
