Hello. I`m a Maya Starter. Migrated from C4D. In Maya, it seems there is no way to use "Length" value when I use modeling tools. Example: when I want to use "Connect Tool" or "Multicut" or "Connect components" the distance desired is based on percent, not length like centimeter or feet...
I checked the pref settings and find nothing. this is a big problem for me. If I want to create one or more new segment(s) on a polygon obj from a corner along 12 cm, I should use the "measurement tools" in order to find the correct point/distance. Is there a way to change the data type used in those tools ?
