Value Per Percent in Modeling Tools.
r_abedi
r_abedi
Hello. I`m a Maya Starter. Migrated from C4D. In Maya, it seems there is no way to use "Length" value when I use modeling tools. Example: when I want to use "Connect Tool" or "Multicut" or "Connect components" the distance desired is based on percent, not length like centimeter or feet...
I checked the pref settings and find nothing. this is a big problem for me. If I want to create one or more new segment(s) on a polygon obj from a corner along 12 cm, I should use the "measurement tools" in order to find the correct point/distance. Is there a way to change the data type used in those tools ?
mspeer
Hi!
In some cases percent values make more sense as most edits are added as history nodes, so when anything changes in the history the edits still work.
Just think of a cube with a size of one meter where it''s divided at 50% vs 0.5 meter and later the input mesh is scaled up by a factor of 3. With the percentage value it still will work.
Tools that use percentage values usually can't be changed to a absolute values.
I recommend to create "helper objects" with the required size, that can then be used in combination with snapping.
r_abedi
Thanks a lot. I should learn more about inputs, output, Nodes. A lot of difference between Maya & C4D.
