UV Unfold, unfold every shell in weird scale
rizkypurnama98
rizkypurnama98
i ve tried re installing the maya, and factory reset by delete the folder in document > maya > 2023
im using maya 2023. and the problem only happen in my pc, when i send the file to my friend pc, and try unfold it in his maya 2023 and everything OK
damaggio
Clicking on that button doesn't mean anything, did you look at the settings? everything has settings.
Also read the documentation.
rizkypurnama98
i already reset the setting to default. is it the setting you mean is Shift + click ??
rizkypurnama98
I have the solution already after other thread in this forum. U need to activate the Unfold3D plugin in windows>Setting and prefference>Plugin Manager>Unfold3d.mll
Thankss
rizkypurnama98
after read i mean
