UV shell unfolded on an angle
Hello, i'm new to Maya. I'd like to ask something.
When i unfold an object in UV editor, the unfolded uv shell has an angle to it. Is there any settings that can make them automatically set it straight and symmetrical when i clicked the unfold option (like a basic cube unfold) ? other than manually rotating them carefully. Thanks!
Fovvl
I think it really depends on how the model was made. I tried unfold the cube then do the same with a similar model you have and it did the same as the cube. After some changes I use the automatic UV and after few "move and sew edges" I had the same result. Well if the model is simple it woud have simple UVs, but as you add more detail I think you will had to work on that manuály.
