UV not showing up?
UV not showing up?
dasjenkalantveld
UV not showing up?
dasjenkalantveld
Community Visitor
Community Visitor
Hi, I have a question. I want to unwrap my selfmade dress, but my UV window isnt showing up as normal? And even inserting a cube doesnt work. What can I do to fix this?? Please help! (Ty! And I am using Maya 2022)
cavescholar
So looking at your panel layout it looks like you docked and changed some settings?
Undock the UV editor panel, go to EDIT > Reset UV editor UI to get back to default. Just in case something was changed.
Reset UV editor UIReset UV editor UI
If that doesn't work then:
You might try RESETTING PREFERENCES ( https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=GUID-393D1ECA-9B6E-4625-B5B1-3F28E62AFB1C ) The link is for Maya 2022 online Help manual, very helpful!
If that doesn't work, then maybe the scene with the character,  was saved with the problem embedded in it.
Good luck!
